LegalBrief
Makes it harder to steal… theft was a early multi problem
There’s a gigantic difference in a 1500 and HD. Payload and towing capacity are practically double. The frame and bed flex under heavy load,the teeth were designed to keep the tailgate alignment to the frame rail. Which prevents the hinge points from binding and crushing the bushings or tailgate when load shifts.There is not much difference between the 1500 and the HD's. The 1500's don't have that contraption. I will be removing mine on the AT4HD, come spring, when it warms up to install the putco bar.
